LP44 carrier in a HP44?
BronKitis
TRS Banner 2012-2015
Spanaway, WA
Have a 78' HD HP44 with 3.54 gears. Was told had 4.11 when purchased. 3.73 is the carrier break. I have a LP44 from 76' with 4.11 gears. Can I use the carrier from one to the other? Thanks.
AJ
No you'll need a 3.73 and up carrier. Don't listen to this guy^^^
Or new "thick" 4.11s. I have my 5.14s on a on a high gear carrier, just bought the thick gear set.
Either way, your buying parts.
Sent from my HTCONE using Tapatalk 2
Maybe RANGERROD you didn't notice or can't READ but he says he has a carrier from a Lp44 from a 76 with 411 gears that why I said the carrier will work in a hp not the gears. Maybe reread it again slowly with a cup of tea and put some glasses on it might take a couple of times but you'll get it.
PS. Just so you don't get confused again RANGERROD the gears will not work, a they say you can learn something new everyday.
The 3series carrier won't work unless you want to buy thick cut gears like stated above that's what I meant. I made the assumption the op wanted to go to 4.11 gears.
And 93 I think I might know a few more things than you and your pep boys pimp my ride ranger. So go suck it. By the way no way that's 12" of lift and if it is big gay truck land is calling your name.
Both of you cut the e-thug bullshit. If you want to be like that, go over to pirate4x4. I don't need to start sifting through dickheaded comments on two sites.
And to answer your question, yes. Your low pinion series 4 carrier will work with REVERSE CUT 4.11s in a high pinion dana 44.
Phhhhew. I'm safe, I only have 10".
No rainbow flags flying from my ride in kinda big straight truck land.
Are you guys both humping each other? and I 'm not talking about blinker88
Ok
