tajvelocity
I tried the lowered thing and I'm over it: I've lost utility, potholes are trying to eat me, and I miss being able to run over stuff. This is a truck after all. It sucks I had to learn the hard way but whatevs. Live and learn. SO...
99 Mazduh B2500 (2wd)/w DJM 4/5 (control arms, stabilizer bar links, shocks, flip kit). Going back to stock height isn't desirable because I need new tires and I might as well get some 30's or 31's on there to increase chest hair and peen size. I'm looking for no more than two to three inches over stock because that seems to be the cheapest route and it will suit me fine. This shall be very budget minded.
I've collected most of all the parts I need and have started the (re)build. Driver's side rear is done I think. Have a look. I have some questions.
Unfortunately, I think the Belltech shackles have just flattened my rear leafs. That sucks and I'm thinking about taking it apart again and adding an add a leaf or something:
Does this look pretty flat to you? Any suggestions?
Old shackle and hanger. Good thing I did this when I did.
Is the shock boot supposed to look like this? There is a ziptie holding it up. Should I remove that and slide it down?
Other side, ready for dis-assembly.
Oh, does it look like I can reuse these bed bolts? They're a little rusty as you can see but they could probably work.
I guess that's it for now. I just wanted to get some opinions before I proceed. Does it look like I did everything right? I know stuff is pretty rusty, but everything seems structurally sound. I wish I could have the frame sandblasted and replace other rusty bits (like those brake lines for example). I also wish I could get a hold of a Ranger 8.8 with a LSD and 4.10's. Maybe next spring. I need to get this thing back together because my daily beater van is in questionable running condition!
More to come!
More to come!
