cdndrtbk
Is it possible to be pulling air into the cooling sytem via a blown lower intake gasket?
More than likely a blown head gasket, warped head or cracked cylinder head is causing the problem if your getting "air" into the cooling system. Is the cooling system pressuring up causing the coolant to over fill the reservior bottle? Also at times the coolant will get an odor almost like raw exhaust if you have a bad
