lostpilot28
- Jan 18, 2012
- Automatic
I think I may have gotten ahead of myself with replacing my lower ball joints. I read a bunch of web pages, watched some YouTube videos, etc, on how to replace them, but didn't notice that they were all 2WD trucks! Doh! Anyway, I started taking things apart, only to stop after I pulled the plastic hub off the wheel and realize I may not have all the parts I need to put it back together if I continued!
So, back together it went. No new ball joints.
I lifted the front of the truck and did the side-to-side, top-to-bottom test to check the ball joints, tie rods, and wheel bearings. Neither side moved. BUT, when I stuck a long pipe under the front wheel and lifted the lower ball joint went up on both sides. Driver side was maybe 3/16ths of an inch, and passenger was a little less...maybe 1/8". I didn't measure to be exact...just estimating.
What's the tolerance on this up & down movement?
Do I even need to replace them?
The whole reason I even started looking in the first place is because my truck has a very slight wandering problem going down the road. Steering feels tight (no play) but it seems touchy.
Any help is greatly appreciated!
