sussman00
- Apr 8, 2008
Hi All,
I've got an issue with my 88 2.9 I'm hoping someone can help with. The truck seems so sound fine. It idles great and doesn't seem to have a miss. However it recently started loosing power. On hills it is ridiculously weak. The gas milage has also dropped. I'm getting 10-12MPG now where I used to get 19 consistently.
At first I thought it needed just a tune up. So I put in new cap/rotor/plugs/wires. I also replaced the air filter and fuel filter. The new parts made it run better. But it didn't fix the power loss.
After reading up on this problem in past threads I have checked the following: FPR does not show any fuel in the vacuum line. I tested the fuel pressure and it looks good. Starts at 40 with the ignition on. Drops to about 33 when I start the engine. If I unplug the vacuum line to the FPR the pressure goes back up to 40.
I also checked the vacuum pressure. It holds steady at 19 which is just about right I think.
I also checked the codes. The only code coming up is 41 - lean condition during the KOER test.
The O2 sensor is not that old...so I am hesitant to replace it. Is there anything else I can try to diagnose the problem? Any thoughts on what might be causing this?
Thanks for your help.
