diverd
- Apr 10, 2009
Help
My 99 Flex-fuel is having the common problem of LOW oil pressure.. Cold I get 50 psi once the engine gets hot the pressure drops to about 10 psi and zero @ idle. I have installed a mechincal pressure.
Is there an easier way of getting to the oil pump without removing the tranny or unbolting the engine and lifting it on it's side??? Do you even think the oil pump has gone bad or could it be the main bearings????
And if I do have to almost have to pull the motor to replace the pump do you think I should just replace the motor it has 155k on it. and what V8 will drop it and bolt right up to my 5 speed manual?
