nedirtbikr
- Dec 31, 2007
- Automatic
Okay, pretty new here in the forum. Have done some searching and found some answers but need a little advice. I have a '99 3.0.
Low Oil Pressure - I have found info here regarding the oil pressure staying way low until warmup and then indicating normal (only does this in cold weather.) Mine does this. According to the info I found, it looks like I should be looking at replacing my oil sending unit. Is this easy to do? "Easy" in the sense that...can I do this with standard tools on my driveway? Also, from what I understand, it is located on the passenger side under the hood. Anyone have some easy instructions for me?
Check Engine light - There appears to be several different things that can cause this. The gas cap being one of them. I think this is my problem. Nearly every time I fill up, the Check Engine light goes dark for a day or two and then comes back on. I have been able to duplicate this many times. My question on this one is...Is it common for the gas cap to "fail"? If so, no problem, just looking for a recommendation on a new one that will "fit the bill" and perform. Should I just get another Ford one or are there some aftermarkets out there that should be fine?
Thanks!
Thanks!
