Papas97
I have a 97 Ranger 2.3 Manual that will crank but not start. Checked with starting fluid and it’s runs for 5 seconds. Checked Fuel Pressure at the rail and it was 22. Cycled key a few times and never went above 22. Jumped relay so pump would run continuously and still 22. Pulled return line off at pump and fuel was being returned at 22 psi. I assumed the Regulator was bad so I replaced it and still got the same results. If I crimp the Return Fuel Line just before the tank I get 45 psi at the rail. Any ideas what would cause this? Fuel Pump was replaced 2 years ago.
