- Aug 10, 2014
- Age
- 33
- Madison, IN
- 4.0 V6
- Automatic
- Tire Size
- 215/70R15
My 1995 4.0 seems to have low fuel pressure. I was measuring around 20psi or so (no longer have fuel pressure gauge)
I have replaced:
I also checked the inertial cutoff switch. All looks good there. Fixed some battery issues, no change.
Getting exactly 12v at the fuel pump connector when the key is turned on (no load). Not 12.4v like I'd expect... Indicates a bad wire?
I also tried feeding power directly to the pump via the inertial switch connector. No change.
I'm running out of ideas... Suggestions?
I have replaced:
- fuel pump
- fuel filter
- pump strainer
- fuel pump relay (from parts truck)
- fuel pressure regulator
- (unrelated?) alternator
