All of the power in the 3.0L is higher up in the rpm range. Is there any way to get more power down low for towing and offroading?
OMG.......
Regearing will NOT hurt performance on a 3L.
It's been proven over, and over, and over, and over, and over, and over.... (should I really keep going?)..... that the 3L needs to reach higher rpm more quickly in order to perform. Hence lower gearing.
I hated my truck with 3.73's, I like it much better with 4.10's, I have a feeling I'd love it more with 4.56's.....all with a 31" tire.
For example: 4.10's with 235 75 R15's would work quite well.
It's all in mechanical leverage. The time and money wasted on intake, exhaust, ignition, etc, won't amount to anything. Forced induction on the other hand......maybe....but that will take some $$$ to setup properly.
The OP never said what gears he currently has, or what mods (if any). Most mods you do, suspension, engine, or drivetrain have both a give and take. They affect performance in one area, while sacrificing in other areas. Simply telling him to get taller gears without knowing what he has is reckless. All you're doing by changing to a taller gear ratio, is moving the powerband lower. By doing that, you get less acceleration in the "top end". On the other hand, you CAN make improvements to your engine that actually add power, rather than just changing when it's available, and make the 3.0 much more liveable.
Big Jim, it sounds like you've got yourself a nice rig! Those levelII's are a great base for some mods! (Although it sounds like you're happy the way it is.)
Higher lift roller rockers have been used sucessfully on pushrod motors for years. Here's some anectdotal evidence you may find interesting: http://www.rangerpowersports.com/forum/showthread.php?t=265087
This person didn't see huge gains in off the line acceleration, but they are gains none the less. The difference would be more noticeable higher in the power band through the 1/4 mile rather than the 1/8th.
