DeanMoriarty
- Jan 26, 2008
Hi there... I'm new here. I tried scouring the forums but cannot find anyone having the same problem that I am. I have a 93 Ranger, 2wd, 4 cylinder, 5-speed.
A few weeks ago I noticed that when coasting in gear, instead of the low grumble I'm used to hearing, I hear a high-pitched whine. I thought it was coming from under the truck, but it's hard to tell. As soon as I slightly press the gas pedal, the whining disappears, or at least becomes almost inaudible. The noise stays consistent with my speed, and the gear I'm in; If I downshift to 3rd at 45mph it is very loud... At 30mph in 3rd it's hardly noticeable. It makes this sound through all the gears, but is loudest in 1st through 3rd. Again, it only makes this noise when coasting in gear, without the clutch pressed down, and not during acceleration.
I should note also... around the time the noise started I'd had trouble getting it into gear, mostly 1st through 3rd and R. I haven't had a problem with this since. I also recently changed the serpentine belt... Not sure if this would affect anything. Any help would be greatly appreciated. Thanks!
