if ring in #6 sticking any ideas idules good except for smoke seems to have pleanty power seems to load up at stop lights blows lot of smoke at take off
besides boring you could try ring free additive in your fuel. seafoaming will help clean the cylinders but b4warned change the oil pretty soon to keep from really smoking the cylinders from loose carbon. you will have to change the oil to get the fluid and deposits from the cylinder. other than that run the piss out of it til she blows.
If it's loading up at idle, it could be a problem with valve stem seal blow-by. It also may be seen on mediate start up and at highway speeds when you shift. Then you may see a puff of smoke. Have someone follow you and watch for the smoke.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
