Lost Lights
trxusrngr
Manheim Pa,
Lost my guage lights and heater lights, its just the lights that are on the dimmer switch. E-Brake light works high beams light work.
WHATS THE PROBLEM?
try checking your fuses..does your taillights work as well? I had an issue where my aftermarket trailer harness shorted, causing a fuse to blow..it was also in circuit with my speedo lights..check it out. Good luck! I hate electrical issues :icon_twisted:
checked fuses, not that. taillights work fine, it wouldn't be bad but it sucks driving in the dark not being able to turn the heater without the cab light on, and not knowing how fast your going.
it might be worth pulling the cluster and radio and checking the plugs..maybe by chance your wiring has come undone :dunno:
