First time, the one that came with the truck was "Rebuilt" by an idiot. We pulled it apart and (it's waiting for me to get the time to rebuild it) The idiot never torqued the pump bolts to the bell housing. So the pump was doing the 'Scootchy-Scootchy' and it had massive pressure problems.
Second was the one from the boneyard, with a recent rebuild. Had I researched things here more, and learned about the crank-spacer? The torque converter would have been in 100% "True" and not allowed to damage the pump seal and bushing.
Third time was getting the pump/bushing rebuilt for same transmission...and it had more internal damage then I counted on.
Forth and (God I hope final time LOL) Another bone yard transmission....this one actually had DIRT and small rocks in the pan?!?!? Looks like the guy dumped it when he pulled it. However!! We cleaned the case...pulled the pan and hosed the snot out of the insides with brake cleaner (4 cans worth)...air hosed it several times....more brake cleaner... And said hell...new filter, converter, seal.. And it's been running fairly good for the last YEAR!! (watch...I'll hit the "Post" button...and overdrive will take a dump tomorrow... LOL)
So that's 4 times in and out..(depressing if you think about it).
The only reason we didn't crap-can the truck at this point? It's got like---Zero rust issues. Light surface rust on the frame in a few spots....But it's damn near mint! body wise. Sure...could use a paint job....light surface rust on the roof in a couple of stone chipped areas..
My step father stated I should just trade it in for a newer truck. But why at this point? I know every detail.....Paid only $600 for it...And I know it's problem areas that can cost me more $$. Can anyone say that about another used car or truck? Most of the time we wind up hitting the 'C-List' or local papers looking for a good cheap 'dependable' ride. What we wind up with? Is dealing with other peoples headaches. I'm into this for let's see: (not to hyjack this thread anymore LOL)
$600 for the truck
$180 for two cylinder heads (bare, world products)
$150 give/take in gaskets
$55 for the battery
$45 for the o2 sensor
$25 for the map sensor
$25 for the TPS sensor
$250x2 for bone yard transmissions
$50 give/take transmission fluid/filters/etc...
$55 for a steering box
$150 for all 4 brakes totally rebuilt (all for the parts, I do my own labor)
$300 in tires
$350 towed and starter install (got stuck at the mall I work from, can't work on anything in the parking lot)
$18 fuel injector rebuild kit
$30 two replacement injectors that could not get rebuilt.
$45 to replace the duff TFI module.....
There's probably a lot more I'm missing...like the $50 boneyard alternator. (some idiot swapped in an alternator from a F150...so the normal replacement wouldn't work with the brackets)...
Yeah...Nuts, right? But owning one of these little snots? It's a labor of love...or insanity. Your choice on that one
S-
