Losing The Stacked Blocks
Greg5567
Virginia Beach, Virginia
I have an 8" Skyjacker Suspension Lift and a 3" Body lift....the suspension kit came with the stack blocks and im trying to get rid of them and from what ive heard I can do so by adding or replacing the leaf springs?
Any help on that, im not to sure about what exactly needs to be done..:icon_confused:
get a new center bolt for your springs and just add some more leafs to your spring pack to acheave the "new" ride height you need..
add-a-leaf may not be enough.
making a custom spring pack would work. so would the half-ton chevy leaf spring swap or shackles (see the tech library).
get a chevy drop shackle and a 3inch lift block and take the other two out
