Toms01PSD
I fixed the freon leak I had at the back of the a/c compressor and filled it up and it feels good. Here's my problem, when I left the shop coming onto the road, I could hear my compressor cycling on/off while watching my RPM's drop and it's making the engine a lot more sluggish. When i'm cruising at 55 it doesn't cycle on/off and my RPM's don't jump up or down. However, when I give it some gas to climb a hill it starts cycling on/off again even if i'm at cruising speed to keep it at the speed limit. Is this common on 3.0s? I have never driven anything with this small of an engine that made that much of an impact. I have low compression on 1 cylinder but I didn't think it would make that much of a difference. By the way, the RPM's drop about 200-250 each time it cycles. Any help is appreciated!
