05ranger
- Sep 1, 2007
I recently started feeling a little problem when my A/c and certain vent settings are on. Most notably the vent setting that blows from the dash and under the dash onto the feet simultaneously. I feel a little power lag in higher RPM's around 3,000, usually when im about to shift the manual transmission from 3rd to 4th. The sensation is similar to when the governer kicks in and you feel that little bit of drag.
I am no expert on A/C systems. DO you guys think its a compressor problem? or something else.
I drive an 05' ford ranger, 2.3 liter, manual, 4 banger.
Thanks guys
ps. i know its common to lose a little power with the A/C on with smaller engines, but I typically stay pretty in tune with the feel of the engine when im driving and this has definitely just developed in the past couple of weeks and it not only occurs with the A/c setting but with that particualr vent setting as well, which has surprisingly always blown cold air into the cab, unlike other settings. wierd no?
Thanks guys
