- Apr 3, 2008
- Age
- 51
- 4.0 V6
- Automatic
Today I was out taking the rig for a drive. Under partial or full throttle the engine would start to bog and lose RPM. I brought it home and checked the codes. With the tool, I got codes 10, 11 and 14.
10 isnt listed
11 says test ok
14 is Ignition pickup was erratic - Ignition Systems
From what I have found on the net so far, it sounds like it could be the ignition pickup or the EDIS. I have seen multiple posts on different engines about the EDIS/TFI getting hot and causing issues. Anymore thoughts on this? Where should I start looking? Is there a heatsink for the EDIS? Can I move it from the rad core support to the cab for example?
It was 100 degrees out today...
10 isnt listed
11 says test ok
