Loose Tranny and No 5th Gear
Ranger-Danger
93'
Picked up a ranger from my father about 1.5 years ago. Its never had a 5th gear and the play in the shifter (in gear and out) is Crazy like 4-6 inches in and alot more when out.
My question is: Is there any chance if i just get a shifter bushing kit and install that, a flush and some New fluid, is there any chance i could get my
5th gear back??
Now currently i can go thru 1,2,3,4 and reverse with a little force but will go. Or is this a larger problem??
Thanks
This happened to my truck. I took my trans. out and opened it up and I found pieces of gears laying everywhere. My trans. was completely SHOT. You might try and drain all the fluid out of the trans. and the take the bottom cover off and just look at it. Its not that hard to do. I replaced my trans. and the clutch was still in good shape. Having to shove it in the gears my just be your synchronizers going out, like I said, mine were shot and it did the same thing.
