loose connectors
nooberiffic
I was trying to figure out why my parking brake light doesnt go on when the brake is on (and the bulb is good, checked it in a slot that lights up), and I saw these two unplugged plugs and have no idea what they go to. They are right by the fuze box under the steering column. Any ideas?
thanks guys.
The first one is your parking brake light switch connector,complete with part of your broken switch still plugged into it :) The second one is the diagnostic connector for your rear ABS.
Thanks man! The PB light flashes on when starting, but doesn't come on when I use the brake. Now I know why. Cant find the part at Autozone.com, Where do I pick it up?
Isnt the ABS diagnostic connector under the hood?
Nope. Grounding that black/orange wire momentarily if the RABS light is on is how you make the light flash out codes. The parking brake switch may be a dealer only item but I can't say for sure.
