- May 14, 2018
- Western Mass.
- 3.0 V6
- Tire Size
- 225/70/R15
- My credo
- If it's not broken Don't Fix It!
Let me start with I have never done this or even seen it done so please treat me like I know nothing on this subject because I only have a basic understanding on this. ( truck specs <--- over there and in my signature below )
We all know with proper maintenance the 3.0L can be a very reliable motor that leaves you wanting more so now that I am about done with all of the replacement parts to get it back 100% minus A/C I am now looking for easy bolt on performance. I will not be, at this time, doing a rebuild into a Romulan motor like @ericbphoto is currently building for his rig (https://www.therangerstation.com/forums/index.php?threads/3-0-wont-be-slow.186203/ ) but still want to get some performance out of it. This leads to intake manifolds and computer chips. From hours of reading with out new heads my 94 stock block has limited options so I'm considering sourcing a chip for the ECM and need more information before pulling the trigger on it. I do not need to pass emissions but it all must be there due to local, state and federal laws so if this buggers my emissions output it wont cause an issue for me. Luckily I don't live in California.
My starting questions are:
1. What does the chip actually change? I'm not looking for numbers just what parameters are changed. I'm just trying to get a better understanding of what the chip does to the base settings.
2. With a chip is there other parts that need to be changed or is this just a simple plug and play style upgrade?
3. What can go wrong when doing the chip replacement other than frying the chips and other things in the ECM from static? I build PC's so I am aware of the need for a grounding strap on when physically touching circuit boards. Example: can it fry other sensors ect. if I goof up somehow?
OBD 1 ECM installed so a programmer is not an option for me.
