Looking for shifter piece!
ZKrimm
Dallas, TX
I posted about this a few weeks ago, and another member helped me out so much!
I have a 1984 Ford Bronco II 4X4 manual transmission. I’ve been looking for a very small piece that the shifter sits into in the transmission.
The member you helped me out, had the right piece, but the wrong size. Does anyone have one available? Or no what’s its called, so I can find one? Photo attached.
Thanks!
Try adding a ruler to the photo or lay a quarter beside it for a better grasp of its diameter
Only a suggestion ZK, not trying to knock it, but it did look rather lost in that empty space. Most of these guys have seen them a thousand times anyway.
Let me ask you this though, you said you're looking for it, and also that it's with the mechanic ?
You’reright should have taken a better photo.
Another member in the group had the part I was looking for (the photo). However, this particular part was too small to fit my Bronco II.
So now looking for a larger version of the same part.
What transmission? It looks similar to a part in the shifter rebuild kit for a M5OD-R1. Kit is from Dorman.
I must be thinking of another post :/
