looking for lift spindles 94 4.0 V-6
offduty
Does anyone know where I can find lift spindles for a 94 ranger xlt 4.0 V-6? What should I use to raise the rear end and how involved is the install for both products?
Thanks Rich
Is this 4x4 or 2wd? If its 4wd you cannot lift it with spindles. You have to get a lift kit that drops the twin beams down away from the truck. Spindle lifts are only for the 98+ years with SLA suspension.
the above is correct, there is no such thing as lift spindles for the I-beam trucks. You'll have to resort to a full out lift kit.
there IS a way to lift a 2wd Ranger without resorting to lift brackets.
though it will require fabricating a center lift bracket for the passenger side beam...
But you'll need to find a 2wd Bronco2.
these accomplished their "lift" by different beam geometry.
(basically the end of the beam where the spindles attach is different)
AD
