locking hub problem - 85 ranger
phacemeltar
i recently bought an 85 ranger. about 2 weeks after purchase, i tried locking the hubs and putting it in 4x4.. and the front right wheel ws having a hard time turning. i havent had much time to look at it but i was wondering if anyone can diagnose this issue or even give me a ballpark figure on getting it fixed. the suspension and drivetrain look really complex. maybe it just needs lubricant or something? i wouldnt mind changing out the hubs, but im not sure where is a good place to buy these items. i love this truck.
Sent from my P01Z using Tapatalk
Wouldn't be suspension is as 2WD or 4WD won't matter.
Good read here on the front axle: http://www.therangerstation.com/tech_library/dana_28_35.shtml
If you have manual hub, then when they are unlocked and transfer case is in 2WD then the front axle doesn't turn.
If hubs are Locked OR transfer case is in 4WD then axle will turn.
I would start by jacking up the front wheel and spin the wheel with hub unlocked.
Then spin the wheel with hub locked, see if that tells you any thing.
Because the front wheels are used for steering there needs to be u-joints near the front wheels to allow them to turn side to side, these should have been replaced at least once on an '85 but if it was not used for 4WD much then maybe they are original.
Diagrams of front axle parts here: http://www.therangerstation.com/tech_library/Dana28Rebuild.shtml
