lockers from a jeep d35
89rangerx
Selinsgrove, Pa
will a jeep d35 locker work in the front d35 in my ranger its a ox locker with 27 splines
If it's a 3.55 and numerically higher carrier, yes, it should work.
The locker itself will fit, however you'll have to get creative when it comes to mounting the shifter, as there's no "cover" to remove to put the OX cover on (probably have to cut open the front of the axle beam, mill the OX cover down 3/16" (the thickness of the beam) and then mount it over the beam).
that sounds like a lot of work just so i can have a cable locker think ill just go with the e locker instead
