Locating Fuel Pump Wire 1994 Ranger 4.0
RangerRyan50
Denver, CO
Hello, I am hoping to install a kill switch in my 94 Ranger XLT 4.0. For extra safety as there has been an increase in truck thefts in my state. I can not figure out how to locate the fuel pump wire to splice my kill switch into… I found the fuel pump relay, but do not know the best way to find the wire after locating the relay… I have very little electrical experience but the videos I watched looked easily doable if I can locate the wire. Any help is appreciated! Next option is a battery kill switch but I don’t want to have to pop the hood every time I drive…
Best place is in the cab
In passenger side footwell mounted to firewall just behind glove box is the Inertia switch
Looks like this: https://www.explorerforum.com/forums/attachments/2010-05-31_211033_inertia_switch-jpg.77025/
Has a red button on the top
The green wire is 12volts IN from Fuel Pump Relay
The Pink wire is 12v OUT to fuel pump
Disconnecting either of these wires would kill fuel pump
Inertia switch is there to cut fuel pump power in a accident, there is a weight inside that will break the connection if there is a sudden stop or roll over
This IS a 20amp circuit so used a switch and wire that can handle 20amps
Just FYI
Visual deterrents are better than things like a kill switch which is invisible
i.e. "the club" or steering wheel brake pedal lock
A red flashing led that looks like an alarm is installed
You can get "travel motion detectors" to hang on the door, they are battery operated and would be place on hotel door to activate if door was opened, but a thief would think its an alarm and run like heck
where would I get travel motion detectors? And I am debating on the kill switch just because my ranger is starting to look really good and truck thefts have been increasing. One of our trucks at the farm I work on was almost stolen recently (of course many farmers leave the keys in their trucks though).
