limited slip
joey7478
1984 ranger
Can you change the spider gears from open to a limited slip? Don't know much about them! Thanks!
L/S takes a whole different carrier as it has clutch paks in it!
You can add a shim to the side gear and make a red neck posi. I've done it in a 9" and a d-28.
Sent from my XT1032 using Tapatalk
The carrier and side gears (the ones the axle shaft go in to) are different from open to LS. The spider gears (the ones the king pin goes in) are the same.
Thanks learn something ever day!
