lights for instrument cluster
this user name may change
Craig, co.
ok so i am trying to figure this out.... i want to add all the cluster lights as in: 4x4, low range, and water in fuel (or is this just for diesels) the pcb is set-up for every light, but the plugs are not so my question is, is how do i add wires to those plugs and were do the wires run to (like for 4x4 do i run them up to the switch?(yes its an electric t-case) or to the t-case? or ???) also do i need to go to the junk yard to find those small lights?
the bulbs are pc194s, they have a regular 194 bulb in them so if you already have the bases you can just change the bulbs, otherwise you can purchase them with the base using the part no mentioned. as far as running power from the printed circuit board to an empty bulb socket, you may be able to solder a wire to the exposed metal traces but that might be a long shot?
what if i go to the jy and just pull the wires out of the connectors and follow them to there source? (and also pull the metal pieces in the connector)
:icon_confused:
