lift questions
twoshoes028
whats the max tire size u can fit without rubbin with a 6 in skyjacker lift and 3 in body lift on a 93 ranger with a 3.0 also any1 know if the aftermarket bodymount brackets on ebay are strong enough to hold up my truck lol
Depends, how much do you want to trim your fenders? With that much lift, I would go with 35's and some dished out rims for added stability. With that much lift, you shouldn't need to trim for 35's if you are running bump stops. If you want to go bigger than 35's, you will probably have to trim. As for the body mount brackets, are your current ones rusted out? As for the body mounts, didn't see any glancing around on e-bay so I can't really comment on them. All I can say is that you get what you pay for. I would try the stealership, some parts stores like carquest might also carry them.
hick
I've got 6" with no bodylift, and I run 33's with no problem. You shouldn't rub with 35's... just keep in mind that it takes more than just a lift to run 35's safely.
I have a 4 inch suspension, 3 inch body, I have trimmed the fenders, and I still manage to mash my tires into sheet metal every now and then. Granted it I am not running extended bump stops, but it is definitely something to think about.
hick
35's but then you'll need gears to turn them too.
