lift question
austinhaynie
i have a 93 4.0 v6 4x4 with coil spring front suspension. If i put 4 inch lift springs in what all would i have to change in the steering and tie rod componets?
with a 4 inch lift kit you need axle beam drop brackets and radius arm drop brackets. The only steering component your would need is a drop pitman arm.
thanks and can you send me a link of where to buy them?
You can get everything through Jim HERE, He also has Skyjacker lift stuff too but for more $$
