lift question
97_Danger_Ranger
Minnesota
I just bought a set of 2inch leveling coils and a 2inch block kit for the rear and im gonna run 31inch tires. Do you think this is ok? Will it look fine? And will i get a full 2inches out of the front end? Thanks
Does your truck not have factory blocks in the rear?
The front end will probably get 2", maybe 1.5". You will need to correct the camber afterwords as it will be very positive.
31" tires probably won't rub, but you wont know until you put them on.
it shouldn't rub. most 4x4 3rd gens and up can run 31's stock. you could probably do 32's
perfect. so the stance will sit about the same as it is stock now? and yes it does have blocks in the rear.
