- Sep 14, 2011
- 2.0 (4 Cylinder)
- Total Lift
- 0"
- Tire Size
- 215/75-15
I have the neighbors 1987 B2 in my yard with no fuel pressure. It did squirt/dribble when I tried the test valve, but not enough to run a test gauge.
The fuel layout appears to be;
Rear bumper --> Lift pump in tank --> fuel not filter/surge puck --> HP pump --> in line can filter --> test port on rail --> front bumper
So I removed the high pressure pump, its dark. No noise, shows open, running 12v to it and nothing. But I wonder why the pump died.
So I ran the lift pump (tank has more than 10 gallons of fresh fuel) and with the lines open at the high pressure pump...nothing. But it makes all the working fine noise at the tank/filler neck.
Should I be able to empty the tank using the lift pump?
