Lift Parts, Help?
Lee_533
Hey guys...I am about to lift my truck and I just wanted some more info on it. Can anyone tell me if I'm missing something? I have: Drop brackets for I-beams, Longer arms, new brackets for arms, leaf springs, shocks, and drop pitman arm....am I missing anything? I'm only lifting it 4"s and my brake lines look fine (I'm still going to extend them though) So is there a part that I still need before I tare into it and get screwed?
By the way...what kind of bolts would you guys recommend using on my brackets?
Any help would be great, Thanks
You have coils I hope, and adjustable alignment bushings..
Yes I do...forgot about that...
u shouldnt need the longer arms AND the drop brakets for the arms. im assuming those are for the radius arms?
Ya it is...And I know I probably won't need them but the kit came with it so I figure why not...plus it will give me better travel and a little softer ride...but what kinds of bolts do I use..I don't have any so I am going to pic some up.
I'd probably use grade 8 or 10.9 hardware, but I may be wrong, that's just my slightly educated guess.
Where can you get the 10.9 bolts?
10.9 hardware is metric, you should be able to buy it anywhere you can find a selection of metric hardware.
