lift on my truck.
thinking about getting http://www.camburg.com/store/susp-s...ranger/ford-ranger-89-95-performance-5-5-kit/
that for my truck.
for the shocks what fox shocks should i get for the front and back please link me to the shocks thank you.
Im by no means an expert but that kit says it gives you 10" of travel. So i'd say a 10" travel shock would do the trick. I had a set of fox resi 10" stroke i was going to put on the front of mine. I was going to order a weld it yourself coil bucket kit from dugfab that looks real similar to that camburg one. They recommended 10s as well for it. For the rear it pretty much depends on what your going to do. Do you plan on lifting the rear as well? New springs? Bedcage? Deavers would be the way to go..but there are other options as well. I had some 14" fox resis for the rear of mine that i was going to fab up a simple bedcage for. Downfall to that is you have to cut a few holes in the bed. I have no idea what will fit under the bed with no bed modifications. If you havent already spend some time over at Dezertrangers.com. There is some good info on ranger prerunners there. But im going to warn you now there is some straight up A holes over there. lol. Hope i helped a little :icon_cheers:
I'm planning on lifting the back. i want some fox resis on mine and I'm going to cage the truck out. i gotta just wait and see on what to do first
if your going to "cage the truck out" ..why not go coil overs? You building the cage? or having it done? Either way you could build your cage and mounts at the same time. Seems kinda like a waste of money to me to cage the entire truck and buy a "bolt on kit" with coil springs. You could probably buy some nice barely used coilovers and some extended beams for that price. It kind of just depends if your paying someone or fabbing all of this yourself.
i'm just going to cage the cab and the bed not the engine area
the cage is being done by me
