Lift of all kinds
Boggin
just felt like sharing i just bought a set of 4" drop brackets, (Rough Country), and i know someone who is making me a set of extended radius arms, (Homebrew), and i know a good place to get some coils and shocks (skyjacker), and also a pitman arm (superlift)
so all together i will have
Rough Country-(drop brackets)
Homebrew-(extended rad arms, rear blocks)
Skyjacker-(coils, shocks)
Superlift-(pitman arm)
will runing a combo of everything make any of it weaker? might be a new question but just wondering if there are any dangers
Running a combo isn't going to make it 'weaker'
The weak spot will most likely be the rough country brackets, I've personally never had a set, but that's what I hear.
Also, the drivers side bracket is probably a 'drop plate', and could possibly punch a hole in your diff if you ever get a Dana 35.
Also, what size coils are you getting??
no its the bracket, from a member on here if i find it i will show you
That there is a drop plate. :D
If your running a Dana 28, you should be fine, just make sure you get some good grade 8 bolts. :icon_thumby:
k thanks will do, but i just thought it was the complete bracket because of the top pic looked like the whole thing untill i seen the bottom pic lol
Yeah, the top one is the stock bracket, it bolts to the 'drop plate', essentially dropping the stock bracket.
How much longer will your radius arms be? Also, is he making the brackets for you as well?
yes for brackets and i planed to ask trs for opinions on the length, what do you think?
I did mine 12" over stock, that way you can retain your factory tranny cross member.
I guess you could make them longer to bolt behind the tranny crossmember, but you won't need that much length.
