Leveling question
cliff476
New York
I just bought leveling coils from Rough Country for my 94 b4000. The old ones measured 10.5 inches and the new ones 15.5. Is this right? I have them installed now but I have positive camber now. (Top lays in) Did I receive the wrong parts or are camber kits required when leveling? I have not seen any post talking about camber being off from level kits.
Sorry wrote that wrong....the top lays out. The truck now sits level so maybe my old springs where that worn. A 5" difference just seemed big but guess the springs are correct. I turned the camber bushing as mush as i could, but its not enough. How many degree's is the factory bushing? Will a aftermaket 4* be enough. I will post photos tonight. Also the ball joints are new so I don't think they are contributing to the camber issue.
Ok, so I just installed -3/+3 camber bushings and I still have positive camber. This was just a level kit, do I need drop brackets? I did a quick alignment and it is driving straight with no pulling. Will toe and caster effect camber that much?
Hello! It really sounds strange... May be you should better check your car in special service. Hope everything will be all right.:icon_thumby:
