nlfireguy
- Mar 15, 2013
- Automatic
I have searched, read, and worked on this for 2 nights now. I am an auto mechanic so I understand "lingo" and offering technical advice is perfectly fine in that I will understand it.
I have a 1998 Mazda B2500. 2X4 Manual 4 cyl. Purchased the truck with a cracked head, purchased another engine, runs awesome now with only 2 minor, but apparently tricky situations.
1) NO SPEEDO------ I have checked, and even swapped out VSS in rear axle (though I had no doubt it would not fix my issue). I have my scanner connected and have vehicle speed in my data and is accurate to GPS. I have No speedo, or odo. I took out cluster, supplied 1.2V to proper wires to motor and the speedo motor functions fine jumping it direct to motor. Where do I go from here??
2) Pass Airbag switch OFF light will not work, and I have a fault code reflecting this issue. Have yet to run down how, or possibly why my pass airbag on/off switch seems to not function.....
Fire away when ready, I am all ears
