r.71
- Oct 19, 2010
- Automatic
I have a 94 Mazda B3000 with an auto trans, I think it is the A4LD (it's a rebuilt from Jasper prior to me owning this truck). About a year ago I noticed it was leaking transmission fluid, and it looked like it was from the pan. So I changed the gasket/filter. It had an RTV-like gasket before, but I got a kit from Advance Auto that had a rubber gasket.
It was ok for awhile, still having a slow leak. But now the leak is a little worse and I'm not sure if it's the pan leaking still. I can see it dripping from the kickdown lever (I think that is what it is called) right next to the pan. The pan bolt at that spot will not tighten down, but all of the others do.
Probably a dumb question
but is it likely that it is the cause of the leak?
