Leaking transmission again!!
justinhill
When I did my torque converter I did not change out the shaft seal so I had to pull the transmission for the second time and changed the seal but once again there is a puddle of transmission fluid under the truck that’s coming from the bell housing, Is there another seal in there or what? This will be the 3rd time pulling this transmission, Let me know what you guys think it is…..:icon_twisted:
Oh this is for the 5r55e transmission btw
did you check the torque converter sealing surface for grooves or cracks? how about the trans cooling lines. i don't remember which trans has them right next to the bell housing
Darn, Bro. You should have changed it out as well. I never ever had a leaking transmission before...not on any of my cars or trucks or bikes. I guess I have been lucky...knock on wood....
