leaf springs
Black_Splash
Huntingburg, IN
I just recently put on leveling coils, afterward I notices the passenger side rear is sagging a little. I was reading about the explorer leafs and was wondering if I were to install those would they lift the rear any? I would like for it to be level.
Yeah Explorer leafs should lift the back about an inch and a half. What you should do is find somebody with a "normal Ranger" and swaps leafs from one side.. :icon_rofl:
Yep, the Explorer leafs should fix it right up. Be sure to look for 4-door ones for the most lift :icon_thumby:
O.K., is it going to level it back out or lift it up an inch and a half higher than the front?
Probably lift it about an inch over the front
Well the leveling coils are 2". Those should have leveled the truck out. Explorer leafs would probably raise them a little above the front.
There is nothing wrong with a little rake. It saves trouble.
Cops are attracted to "overloaded" trucks. If your truck was level.....a 5 or so bags of concrete, etc....would sag the rear....making it looks like you have alot more weight in there.
So an inch to play with isn't that bad.
