leaf springs
509lifted
Firefighter
chelan washington
ok so i have a 92 expo and as most know the leaf springs are sprung under the axle, well my rear end sags so i was wondering would a helper spring work the same to lift it some as it would for a spring over setup? :icon_confused:
Yes. They will serve the same purpose.
If it is a flat spring basically a block then no. You need to put an add a leaf in it.
