jeff4891
gwaii's method is the easiest and quickest way to do it.
i made the switchcrc spray? That stuff ought to work good for shrinking a shaft diameter that needs a bearing pressed on it.
and on the seventh day god said let there be light, but there was none. so i turned on the switch and there was light and it was good.
So.....who made the light switch......Levitron, or God?
gwaii's method has worked and also, more often failed me, the whole stud started turning...actually the rubber turned in its casing, or i end up twisting the threads off..
i just use a cut off wheel for the bolts on the hanger/shackle, and rebush. usually requires a 5 or 6 inch cutoff on a 4.5 grinder and due diligence, its very dangerous and easy to mess the wheels up and grenade them.
but quite fast.
i would not buy that many sawzall blade if i could avoid it with the grinder.
when trying to reuse the old bushing its a real circus show most times if the sleeve and bolt shaft are "growed" together.
