- Sep 22, 2007
- Michigan
- 2.9 V6
- My credo
- A legend to the old man, a hero to the child...
Will these work to check crank rpm to set/check idle speed?
No i got a good timing light. Just wanna use it to check/adjust idle rpm on various thingsYou should be able to measure crank speed with it. But you can not set timing because it doesn't have a trigger signal to synchronize with spark.
Could clean the pulley before applying the tape. Just a thought. I know it's radical. But...should work if you can get reflective tape to stick on an oily pulley/shaft.
Thats mostly what i want it for. My ear for idle speed isnt as good as it used to be. As long as it gets me close im happy.We use strobes at work for checking RPM of machinery. They work great as long as the RPM is very stable. I tried to use it at home on a lawn mower engine but it didn't work real well. The RPM moves around a little bit and I couldn't get a great read on it, but it got me close enough for a lawn mower. I'm not sure how precise you'd like to be, and I'm not sure if the laser one would suffer similar issues. I bought an automotive digital multimeter off ebay a while back that also does RPM using a signal from the coil. It was not very expensive, and may work better than the laser one.
I thought about that but i would also like to use it on vehicles with a carbAs a small engine specialist for the last 45 years, I would highly recommend Briggs and Stratton #19200 tach. It is called a sirometer, and measures harmonics of any rotating shaft (even electric motors), with a fine wire that you move in and out by turning the dial and vibrates in a circular pattern on the end loop when you hit RPMs as read in the window of the devise. Just place it on top of the motor on any hard mounted component (not plastic shrouds). Takes a while to develop a feel for its function, but is cheap at $24, requires no batteries. You would be surprised how accurate it is compared to a digital tach that costs 4 times the price, usually within 10 rpm or so.
