lil_Blue_Ford
Cut & Weld
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- 4”
Ok, so I'll admit, despite having a decent desktop that I love (and almost enough parts to build another), I miss my lappy. A lot.
My aging IBM Thinkpad T-22 has been mine since 2001, and yes, I know it is ancient. But it was fine for ~75% of the stuff I do everyday and being portable was a great help. I set it aside just before building my desktop because it started having issues. The battery died (will not hold a charge) for the second time, I suspect the NIC card died (will not connect via 56k modem or ethernet to the internet), and then came the topper.... I fired it up one day, it showed everything on my desktop like normal, but when I clicked on something to open it, nothing would happen. Then it went to a blank white screen.
I suspected that either the hard drive, motherboard, or memory was bad (I know that covers just about everything). So recently I got back to playing with it, fired it up and ran a mobo test and a memory test, both came back with no errors found. I haven't tested the HD yet, but I did look up a price ($55). Not sure what else I should check or even if it's worth trying to patch my old faithful IBM back up (I ran it nearly 24/7 for around 7 years, it's already on it's second HD).
Specs:
IBM Thinkpad T-22 Type 2647
900 mhz P-III
256 mb so dimm memory
40 gig samsung spinpoint M HDD
cd-rw drive and a 3.5" floppy
twin PCI slots
Windows 2000 Pro
So I'm kinda looking for ya'lls thoughts on fixing that one (or if anyone has a T-22 on it's last legs that they'd be willing to part with cheap).
Now, my buddy gave me a Toshiba Satellite A105-s2141 that kept giving him the infamous BSOD. I suspected after a quick look around that it just got loaded up with crap and needed a reformat to get it back up and running. I tried running my copy of Ultimate Boot Disk, but it wouldn't boot - at all. So I stuck my copy of Windows XP Home in and told Windows to zero the drive and reformat. Got it all loaded and started through letting windows update itself and trying to get some of the updated drivers and such. Then after installing one of the windows updates, bam, BSOD again. It's back to giving me a BSOD every time I start it unless I stop it before it all loads and tell it to go into safe mode. In safe mode it'll run forever. I have no idea what to do now, I'm not even sure how to test anything like the memory and hard drive without being able to load Ultimate Boot Disk. My buddy said that if it needs a new HDD or something, he'd rather just get a new one and I can have the old one to play with, but I don't even know where to start on this one.
Specs:
Toshiba Satellite A105-S2141
Intel Celeron M 410
512 mb DDR2 RAM
80 gig Travelstar HDD
cd-rw/dvd-rom drive
Specs:
900 mhz P-III
twin PCI slots
Windows 2000 Pro
Specs:
Intel Celeron M 410
512 mb DDR2 RAM
cd-rw/dvd-rom drive
