gandrimp
- Nov 19, 2015
- Automatic
The truck is an 03 FX4 and I believe it to be a level ll. I am wanting to raise my vents to keep water out, I have found the rear axle vent which appears to run just below the fuel cap inside the rear qtr panel. The front axle vent ends at the master cylinder ( it needs replaced due to breakage ). The transfer case might be right behind the left head around the bellhousing bolt area, does this sound right? The transmission, if I am seeing correctly comes from the top of the case, and the turns down to about the pan gasket? Why?
Is there a fuel tank vent? Where?
TIA
TIA
