Just replaced the transmission
Gallucci
Bowman, SC
Just replaced the transmission in my 94 ranger with 4.0 a4ld and now it's not cranking
Did you plug the transmission range (neutral safety) switch in? Is the battery hooked up? Is it in park? Will it crank in neutral?
There’s quite a few things that could be wrong.
Everything is plugged and bolted in. All I'm getting is a knocking from the starter.
Battery is dead. Or the flexplate is jammed because you installed the torque converter improperly.
