Just Plain Stupied
Smoke rings out the exhaust sound cool :headbang: , probably not a good thing though.
sounds like either the o2 sensor is bad, or you have something wired weird.
im not familiar with the ALMIGHTY 2.9 :icon_twisted:
come on now!!!! tell me how to clear up the rich condition form idle to half throttle (without sticking the sbc in the '36...pleeeeeze)
ohh, what does the tempurature gauge read?? and does it run better when its cold as opposed to when its warm.
might be a bad tempurature sensor. the engine could be staying in closed loop and nver go to open loop. this will cause it to run rich, not idle right when hot, and smoke on acceleration.
:icon_hornsup: :icon_hornsup: :icon_hornsup:
:beer: for you doorgunner, :icon_pepsi: for me, im noit 21 yet :shok:
How much more insperation do you need?????????????
I'll help you out........
SBC = VVVVRRRRROOOOMMMM (wheels screech and burn out into the next gear) VRRRROOOOMMMMM
2.9 = cough choke die restart and repeat
Imagine what the SBC would sound like breathing through those Harley mufflers.
Need more insperation?????
hyennas!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
But The Sbseee Swap Could Have Been Done Already With All The Time I've Spent On Eec/ecm/egr/eft/ent/act/iac/obg/gyn/stp
Sleeep....need Sleeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
Add a couple of Ys to the end of that and you could be Fonzy.
:cool: 'Eeeeeyyyyy :icon_thumby:
I'd like to read you guys a quote............................................................
you rang?? ehhhh? keep at DG your just about done:headbang:
dont make me come down there:shok:
Up-date!!!!!
Shake-down cruise.....
150 miles round trip......
Average speed 60mph....
Max. speed 85mph..(man...this truk rides smooth/gotta watch the speedom.)
Engine temp. 180*-190*
Oil Press. 40# @ 60mph
Tach 2200rpm @ 60mph in O.D.
" 2800 rpm @ 60mph O.D. off
Volts 13.5v
Fuel 12 mpg (I gotta find out why it's runnin so rich/It got 24 mpg previously)
Note: I found my 13mm box end wrench.....after about 75 miles it worked it's way out of the frame & bounced down the street when i pulled into a small town to see what was rattling under the cab.....LOL
Question(again): why ain't my computer letting me read the codes with my $39 reader????...I cleaned the pins & connectors/checked all the ground wires at the connectors....it still won't let me do the test lite thing either!!!!!!!!!
Mabey the computer is broke and in limp mode and cant get out of it.
SBSEEEEEE time!!!!!!!!!!!
.Y E S ! ! !
(but don't tell blackwidow....I want it to be a surprise....)
Event Coverage
TRS Merch
