Okay, diagnostic routines. I'm not responsible if you blow up your truck or waste your money, blah blah blah:
157/DC10 "indicates MAF signal went below 0.4V sometime during last 80 warmup cycles". Procdure is to inspect wiring and MAF. Expected output (MAF pin D) is 0.36-1.5V. Resistance between D and all other pins should be >10kohm.
211/NB2 immediately redirects to 214/DR1, which can be caused by the crank sensor, cam sensor on California trucks, ICM, PCM/EEC, or obviously any of their wiring.
Assuming the wiring checks out, it looks like one of the most useful tests is DR8: does CID AC voltage (ICM pin 2 on federal trucks) vary by >0.1V with varying RPM. Procedure for yes is replace PCM/EEC (this manual covers dozens of vehicles, most without ICMs. I would personally test the ICM first), no is replace crank sensor.
