just curious
bf750
Ky
It is what it is
:shok:will a 3.8 v6 boat up to a 302 transmission:icon_confused:
Trick question :)
There are two 3.8l bolt pattern versions
The 3.8l from a Front Wheel drive vehicle will have the Vulcan bolt pattern so Ranger 3.0l trans would bolt up, but not 302(5.0l)
3.8l from a rear wheel drive does have the Windsor bolt pattern(ford small block V8) so would bolt up to a trans from a 302(5.0l)
The holes in the block are metric threads, so be careful, if you use standard thread bolts they will start OK and then cross-thread.
Good read here: http://www.therangerstation.com/tech_library/3_8_Conversion.html
thx this is good stuff
