CraigK
- Nov 17, 2007
- Automatic
Tell me I didn't screw up terminally (for my compressor).
The compressor was working fine, but the system had a leak and would not hold freon (94 Explorer, not the BII). So I replaced the (leaking?)condenser, high pressure line to and from the compressor (one piece), the accumulator, and swapped out the orifice tube. Then sealed the system up.
I ran a compressed air/venturi type vaccuum to evacuate the system for ~1/2 hour (instructions say run 10 min), so I had at least some, if not complete, air removal.
Then I added one can of "Arctic Freeze" R-134a, which has 11 oz. R-134a, and 1 oz. oil. Everything was A-OK, and the compressor was cycling with increasing time periods as the R-134a was taken into the system (~20 minutes). The hissing leak seemed to be gone.
Then I set up the second can of the same stuff, and again, everything A-OK for a while, with compressor cycling with increasing on times, and some actual cooling of air. When the second can added enough freon to keep the compressor on, it ran 100% for about 2 minutes then began a HORRIBLE SCREECHING. This appears to be a compressor seizure. The compressor is VERY HOT to the touch, and appears to be seized up. Crap.
Questions:
Is the compressor likely to ever run again after it has cooled down??? Any special procedure to help this?
Oh yeah . . . What type of OIL should I add (PAG or Ester, both seems to be for R-134 systems???) Where should I add it to get to the compressor in a hurry? Into the accumulator? How much?
Any help appreciated. I have a long hot drive to make this weekend.
CraigK
Questions:
CraigK
